Had the clutch and flywheel done (also CV/ball joint). It keeps dropping revs and stalling, fitted a new map sensor which has made no difference (vacuum line is fine).
Most annoying thing is its intermittent and the check engine light comes on only for a bit and no codes are stored. So I've got no idea what's causing it!
Fuses are fine, earths are okay as far as I can tell.
Shortly before idle problems it was only running 0.5 instead of 1 bar.
Also boost gauge isn't getting a signal but I figured that may be a faulty sensor (electronic). But for that to go at the same time, I dunno..
Unplugged IACV, no difference.
Running Mine's ECU, stock FPR, stock pump (could this be failing?)
>https://www.youtube.com/watch?v=yQKhNFviEyU
Really want this sorted, would appreciate any help!
Amjad
Just had a look around that area, looks like everything is intact. Only plug that isn't connected is a 2 wire one that I believe was for the cat temp sensor.
No difference with TPS unplugged either :(
Fuel pump prime video
>https://www.youtube.com/watch?v=DEbrw7YRT2c
Could feel fast pulsations in the fuel line at the filter, normal?
Sorted. Rechecked everything and map sensor had some damage from when I was adjusting bracket, repaired and car is working fine :)
Thanks Colin!
So an update on this, the morning after I thought the issue was fixed the car conked out again!
Checked plugs because there was a definite misfire and the #3 HT lead was covered in oil! Spark plug seal at fault then, thanks to ID-Workz I've got a new cam cover set with spark plug seals and nut washers. That'll be going on asap, but car is sorted for now :)
