Charlie28 Posted March 12, 2015 Posted March 12, 2015 What size bolts are you guys using to attach your block to the stand? And where are you mounting it! Any pics would be great! Cheers, Charlie Quote
Ollieh17 Posted March 12, 2015 Posted March 12, 2015 M10 fine thread if i remember right. Take flywheel and clutch off and bolt through the engine stand into the gear mounts Quote
Ollieh17 Posted March 12, 2015 Posted March 12, 2015 The same size yeh but they had to be longer to fit through my stand Quote
Charlie28 Posted March 12, 2015 Author Posted March 12, 2015 Think there M12x1.25 after some reading! Quote
Ollieh17 Posted March 12, 2015 Posted March 12, 2015 Could well be i wasnt sure if they were 10 or 12 tbh ill double check later. 10 just seemed more likely. Quote
Ollieh17 Posted March 12, 2015 Posted March 12, 2015 Yup find my old thread. They are m12 x1.25 i had to buy 90mm long ones and still use spacers so may worth measuring the engine stand mounting plate Quote
Charlie28 Posted March 12, 2015 Author Posted March 12, 2015 I've ordered some 110mm ones. See how i get on! Quote
Ollieh17 Posted March 12, 2015 Posted March 12, 2015 May be worth getting a load of spacers too bud just incase Quote
RobSR Posted March 13, 2015 Posted March 13, 2015 I've got m10;s in the lower outer two with nuts on the back and then i need to order some longer ones for the top two so have an axle stand mounted to the engine stand atm as it was sagging abit with just the two in. Quote
Charlie28 Posted March 15, 2015 Author Posted March 15, 2015 I ordered some M12x1.25 100mm long bolts but there too long. Going to get some 80mm bolts and that should do the job Quote
