sosolid Posted March 18, 2015 Posted March 18, 2015 How do setup the ct9 on a glanza so that you can use the hi/lo button with a HKS actuator. The standard actuator has 2 nipples coming out of the top whereas the HKS has one. So how would you connect it up and still run 1bar at high boost.? Quote
ReeceGolliker Posted March 19, 2015 Posted March 19, 2015 I've been told you can use a T-peice to run the HI/LO boost. Quote
crispyeel Posted March 22, 2015 Posted March 22, 2015 (edited) Very straight forward to set this up. I was running mine like this before I fitted the ct12 The single pipe that goes from the actuator to the turbo, cut and use a t-piece. Run a pipe from the t-piece to your hi-low solenoid. Run a small second pipe from the solenoid but tuck it away and allow it to vent to atmosphere. Worked perfectly for me. I set my actuator to .8bar and when on low boost it would reduce boost creep issues on my old setup but when on hi was crazy. Hit cut most times when I accelerated hard Edited March 23, 2015 by crispyeel Quote
