garyJ7 Posted March 28, 2015 Share Posted March 28, 2015 Threw my wee 99 starlet in for its MOT with just a due tyre change and she flew through. Back brakes on the limit tho so i'll need them sorting, also guy said the drums were quite rusty, so il get that done. Had pads put on front just less than 1k ago so there grand, I'm thinking a full service while its in, theres 126k miles on it, are they know to go on with high milage? or option B is to perhaps sell it as is and I'm kinda not so keen on that option as I've kinda grew attached to my wee starlet over my 1 year ownership, never let me down once bar one time but that was my fault as i drained the battery leaving inside light on. What would you do? Quote Link to post Share on other sites
K24_glanza Posted May 11, 2015 Share Posted May 11, 2015 It probably hasn't done as many miles as you think. Some of that might be kilometers. Quote Link to post Share on other sites
Lukee Posted May 13, 2015 Share Posted May 13, 2015 its a uk spec n/a so will all be miles, also he said he has drums on the rear which confirms it as the v's and gt;s got rear discs, but i wouldnt say thats too high mileage follow your heart bud:) could make it a show stopper in the near future never know Quote Link to post Share on other sites
Calum122 Posted May 15, 2015 Share Posted May 15, 2015 There should be no reason for it to fail. Provided all the maintenance is kept up to date, regualr oil and filter changes, then it should go on and on. The reason why the engine would fail would be because of inadequate lubrication to critical componets. The engine is designed to be in perfect harmony and therefore should have no reason to fail. However, swarf in the oil can cause premature wear the crank journals, once that happens it won't be long before then engine goes. Those cars don't cost the earth, you won't see much gains from just selling it. Better to drive it until it breaks. It's unlikely to just fail with no warning. The problem occurs when it comes to consumerables, clutches, tyres, batteries etc...and then you have to say is it worth while. Even if the engine develops, knock, wear, etc...a full engine rebuild will cost less than you think. If you delivered the engine to a specialist, you're talking around £600 for the parts + labour. Well at least that is what it cost my brother to have his GT engine done, looking at the paperwork anyway. God knows what tha means. Drive it till it goes, then decide what you want to do. Point being is engine failure, it's one of those things. And if you're smart, it'll just be minimal work. Crank reground, new bearings, seals, pistons and rings. Plus the gaskets. All of which genuine doesn't cost that much. Then, you have a car with ZERO mileage and you know as a fact will last you a lifetime. I'd say the only thing that really bothers me is rust. The cancer of cars once it starts it difficult to stop and needs to be cut out. If the shell is mint then happy days, there is not a lot that can't be fixed. Quote Link to post Share on other sites
