Noticed the steering wheel in my EP82 vibrates/shakes on idle!
Fine when moving just when I'm stationary it does it!
I'm guessing it's an engine mount ? Any idea how to tell which one without having a proper look ?
Randomly it also gets worse if I turn the heater setting up haha
I get this as well, it only does it when the engines not up to temperate and therefore idling higher than it should! If it vibrares all the time you could try altering the idle speed to see if that improves it as said above.
check the power steering reservoir if its not below the min level
