muin1331 Posted April 13, 2015 Posted April 13, 2015 Been experiencing a rev cut like symtom in my ep82....running a 5efte with a td05...changed my leads, rotor and cap...but still have this problem....car can drive normally alright, when I throttle it I have almost no power due to the rev cutting...I can't rev past or it cuts/ misses....help would be amazing right now I'm at my whits end with this problem 😔 Quote
Stu Posted April 13, 2015 Posted April 13, 2015 Pull the cap and rotor off and look at the pickups for the 24tooth trigger wheel - make sure there isn't any metal swarf on them or rust. Have had similar issues on customers cars and this has been the fault. Quote
muin1331 Posted April 19, 2015 Author Posted April 19, 2015 (edited) ill give it a look now and let you know stu, thanks for helping! Edited April 19, 2015 by muin1331 Quote
muin1331 Posted April 19, 2015 Author Posted April 19, 2015 Pull the cap and rotor off and look at the pickups for the 24tooth trigger wheel - make sure there isn't any metal swarf on them or rust. Have had similar issues on customers cars and this has been the fault. got quite abit of rust on them stu can I sand them down? Quote
Stu Posted April 21, 2015 Posted April 21, 2015 You can try but the tollerances are very exact and making changes can effect the wave form it produces.Just swap in another dizzy with better pickups would be my advice Quote
