first test drive in the glanza today, first thing that i noticed it that it isn't revving freely. struggles though the whole rev range on and off boost, currenty running .5 bar and have the FPR set to 45 PSI
I've checked for boost leaks so it isn't seem to be that but i will 100 percent confirm this with a boost leak test.
Turbo is a speedvision ct9 hybrid.
any thoughts guys?
Check sprak plugs and duel filter. Those two items are easy neglected from maintenance.
Can you post a video of the problemen so we can hear and see whats it like.
Cheers, wouter
will do mate, plugs seem to be ok, i've put the old fuel pressure regulator on and it pulls fine now, main issue now is the fact that white smoke is prouing out of it :( i think it's turbo related
white smoke is usually caused by water i think not turbo
or overfueling.
could be miss installing the fpr. not ment to dissrespect but check the fpr is still good. or maybe mistake made with the fuel lines.
good luck and let us know.
cheers,
wouter
or overfueling.
cheers,
wouter
it was installed correctly, just not set up properly. opps haha
