Even so could indicate ring failure, might be best to get it connected back up to the inlet mani or run a catch can setup, get a compression test done for peace of mind
I cleaned the filter .connected pcv valve back up . Seems spot on now. My mechanic said its will b fine he said if it was rings it would be spitting out oil and smoke.
