andy91145 Posted April 21, 2015 Posted April 21, 2015 Had cams fitted the timing and ignition timing has been set but the idle is all wrong cold starts it want to idle at 800 and hot it is about 1100 of you're driving and dip the clutch feels like the car is going to cut out Quote
gazza g Posted April 21, 2015 Posted April 21, 2015 When I have had updated cams on my cars I have had to set the idle at around 1100 as its very unpredictable Not sure why it's idling low when cold though, wax valve or icv maybe Quote
morgey Posted April 21, 2015 Posted April 21, 2015 My 4age with 264/256's idles at 900 and is fairly smooth. They are designed as drop in cams though Quote
turbo Grant Posted April 21, 2015 Posted April 21, 2015 I had to mess around with my idle drew after fitting the cams. All settled down now I've done that and mapped it. Quote
andy91145 Posted April 21, 2015 Author Posted April 21, 2015 I've been adjusting the idle with the screw but like it's been said the idle is so unpredictable at the moment Quote
