jamesh Posted April 24, 2015 Posted April 24, 2015 Just fitted my xxrs and I know the rear needs rolling and mine are a little bit rolled from last wheels rubbing lol. The Thing I need to know well is does rolling the arch stop the rubbing or do I need higher springs. Also on my front I have fiberglass vent wings do you remove the bit inside as The wheel rubs on that when turning Quote
_shaun_ Posted April 24, 2015 Posted April 24, 2015 if there anything like the 527s youll need arches rolled stretched tyres and ull likely get minor scurbbing Quote
jamesh Posted April 24, 2015 Author Posted April 24, 2015 Will do the rear properly but still dont look like its going to clear the arch lol.. what about the front should I remove the black infill? Quote
_shaun_ Posted April 24, 2015 Posted April 24, 2015 i assume they will be et0 8.5j ? and you can either mod the black pastic trim or just remove it. i just binned mine Quote
jamesh Posted April 24, 2015 Author Posted April 24, 2015 They are et0 8j.Yh I will just remove it just wanted to be sure it was ok to. Quote
_shaun_ Posted April 24, 2015 Posted April 24, 2015 its just to stop shit getting under the wings and some in the bay. if you only drive in good weather or clean the car often enough its fine Quote
jamesh Posted April 24, 2015 Author Posted April 24, 2015 Its my daily. Will have to clean it every time Lol Quote
