in answer to ure question if you did for some bizarre reason want to do that yes the fcd would make the ecu underfuel to an increasing degree the lower the number you went.
So if I put my foot down it wouldn't wanna go anywhere and I lifted my foot up slowly it goes abit better? I don't.think my mechanic removed it wen I tested it today
The lower number you went?
Edited by chrisholly
Depends on the fcd to be honest the jam fcd doesn't actually alter the signal u till your about to hit fuel cut its the safer of the pikey FCDs
