So if tdo4 has a smaller exhaust prop then would it spool a little sooner? Just want to be sure as I'm on the look out for a turbo. Is there any difference to the compressor housing then or is it just a small (not really noticeable) difference.
Thanks for the comments guys.
yes smal bit maybe 200 rpm ???? not much diference really the smaller the exhaust prop the faster it spools , if you want faster spoot tf035 and a billet compressor housing and wheel upgrade will do wonders fast spool and big cfm boost :) :)
