Hi my car drivers fine till it go's over. 0 into boost put my foot down feels like no midrange power till I lift my foot up off the peddle alittle and it pulls abit till I put my foot down more again
Checked and tested
map sensor
Timing
Vac piles
New plugs
New leads
New dizzy
Everything to do with the ING
Don't have a fpr or played with fuel all standard injectors was working fine should be OK but changed the turbo don't.think that would matter will it
Edited by chrisholly
  • 3 weeks later...
Have you checked ignition timing ?? I had the same problem with my car and when i spoke with my tuner and studied the power graph he said that my problem at the mid-range rpm was the ignition timing ..
No I got it from someone on here 1bar not standard
And I have.tested with hand pump etc works fune
so your running a bar on stock fueling ????
