chrisholly Posted May 5, 2015 Share Posted May 5, 2015 Hi my car drivers fine till it go's over. 0 into boost put my foot down feels like no midrange power till I lift my foot up off the peddle alittle and it pulls abit till I put my foot down more again Checked and testedmap sensorTimingVac piles New plugs New leadsNew dizzy Everything to do with the ING ;( Quote Link to post Share on other sites
5e colin Posted May 5, 2015 Share Posted May 5, 2015 overfueling i think have you raised Fpressure ??? if not @ injector might be faulty Quote Link to post Share on other sites
chrisholly Posted May 5, 2015 Author Share Posted May 5, 2015 (edited) Don't have a fpr or played with fuel all standard injectors was working fine should be OK but changed the turbo don't.think that would matter will it Edited May 5, 2015 by chrisholly Quote Link to post Share on other sites
Ryan_EP82 GT Posted May 5, 2015 Share Posted May 5, 2015 is the actuator fucked? is it still standard actuator? Quote Link to post Share on other sites
chrisholly Posted May 6, 2015 Author Share Posted May 6, 2015 No I got it from someone on here 1bar not standard And I have.tested with hand pump etc works fune Quote Link to post Share on other sites
SkevosEP91 Posted May 22, 2015 Share Posted May 22, 2015 Have you checked ignition timing ?? I had the same problem with my car and when i spoke with my tuner and studied the power graph he said that my problem at the mid-range rpm was the ignition timing .. Quote Link to post Share on other sites
SkevosEP91 Posted May 22, 2015 Share Posted May 22, 2015 Sorry mate didn't read all of that you stated you checked Quote Link to post Share on other sites
Matt1878 Posted May 23, 2015 Share Posted May 23, 2015 Check that you have the vac lines and everything right trom turbo to actuator etc. Quote Link to post Share on other sites
5e colin Posted May 23, 2015 Share Posted May 23, 2015 Don't have a fpr or played with fuel all standard injectors was working fine should be OK but changed the turbo don't.think that would matter will it No I got it from someone on here 1bar not standardAnd I have.tested with hand pump etc works fune so your running a bar on stock fueling ???? Quote Link to post Share on other sites
