Car wont start.. ignition is all fine fuel pump working. But fully turn key to start nothing... can bump it piece of piss. Battery level fine.. just seems like something electrical not starting the starter...
Any help would be much appriciated
Check fuses and relais and do a v4 measure. 1: battery voltage 2: plus from battery to starter 3: voltage over starter 4: ground after starter. This will check if everything is oke.
Good luck
Check wiring to starter is not corroded just had another person with a starlet have a similer issue and he just cleaned all the terminals up
Checked all wires for supply and was all good.
Dapped it with a mallet and all good sinse so guessing brushes starting to wear in the motor
most of the time its the coil of the solenoid that losses strenght so it cannot push the pinion out of the housing.
