fordie_glanzaV Posted May 9, 2015 Share Posted May 9, 2015 Car wont start.. ignition is all fine fuel pump working. But fully turn key to start nothing... can bump it piece of piss. Battery level fine.. just seems like something electrical not starting the starter... Any help would be much appriciated Quote Link to post Share on other sites
Kayleighhep82 Posted May 9, 2015 Share Posted May 9, 2015 I'm having the exact same problem Quote Link to post Share on other sites
satyrs Posted May 9, 2015 Share Posted May 9, 2015 Check fuses and relais and do a v4 measure. 1: battery voltage 2: plus from battery to starter 3: voltage over starter 4: ground after starter. This will check if everything is oke. Good luck Quote Link to post Share on other sites
Glanza-Ben Posted May 9, 2015 Share Posted May 9, 2015 Check wiring to starter is not corroded just had another person with a starlet have a similer issue and he just cleaned all the terminals up Quote Link to post Share on other sites
fordie_glanzaV Posted May 9, 2015 Author Share Posted May 9, 2015 Yeh gunna check the wires tommorow.. Got hold of new starter now thow if i need it. So hopefully sort it asap. Quote Link to post Share on other sites
fordie_glanzaV Posted May 10, 2015 Author Share Posted May 10, 2015 Checked all wires for supply and was all good. Dapped it with a mallet and all good sinse so guessing brushes starting to wear in the motor Quote Link to post Share on other sites
satyrs Posted May 10, 2015 Share Posted May 10, 2015 Checked all wires for supply and was all good.Dapped it with a mallet and all good sinse so guessing brushes starting to wear in the motor most of the time its the coil of the solenoid that losses strenght so it cannot push the pinion out of the housing. Quote Link to post Share on other sites
