turbominicooper Posted May 10, 2015 Share Posted May 10, 2015 so i have an intake off a 5efhe spare and was wandering if it can take a turbo? if so are there any benefits over the normal turbo intake? Quote Link to post Share on other sites
5e colin Posted May 10, 2015 Share Posted May 10, 2015 if its from a 5efhe gen1 then ist the same mani with a 50mm tb and yes can be used but you nead to weld a bung on for the ait sensor :) Quote Link to post Share on other sites
turbominicooper Posted May 10, 2015 Author Share Posted May 10, 2015 On 5/10/2015 at 10:42 AM, 5e colin said: if its from a 5efhe gen1 then ist the same mani with a 50mm tb and yes can be used but you nead to weld a bung on for the ait sensor :) is that 50mm the same as the 4efte intake or better? i take it thats the sensor that goes off to the airbox on the NA setup? Quote Link to post Share on other sites
5e colin Posted May 10, 2015 Share Posted May 10, 2015 tb is diferent but works to its 50mm and 3 pin tps ( as turbo ) strait fit on 4efte loom and yes on the na the sensor is on the airbox on 4efte in the manni ( sensors are diferent !!! ) Quote Link to post Share on other sites
turbominicooper Posted May 10, 2015 Author Share Posted May 10, 2015 superstar as always. cheers colin Quote Link to post Share on other sites
