chris69 Posted May 12, 2015 Posted May 12, 2015 anyone know the size bung i need to de-wiper my ep91? Quote
rob_bower Posted May 12, 2015 Posted May 12, 2015 Go to b&q get a threaded tap blank in white plastic and then paint it. Quote
Kingofcars Posted May 12, 2015 Posted May 12, 2015 I can cut you one at work, give me a couple quid postage ? I literally did it last night on mine, cut out a circle of 2mm White acrylic with the laser machine and super glued it in... Quote
Dan.GlanzaV Posted May 12, 2015 Posted May 12, 2015 King of cars I would be up for sending a couple of quid to you if u could cut me one of the wiper bung in the white acrylic or if your going japfest could get it off you then ? Quote
Kingofcars Posted May 13, 2015 Posted May 13, 2015 Not going Japfest unfortunately :/ But its only small so i can post in a letter to you so should be quick delivery.. All you'd have to do is super glue the edges and pop it in.... I measured mine at 29mm so double check your size and send me a PM pal Quote
Dan.GlanzaV Posted May 14, 2015 Posted May 14, 2015 No will should be the same as your I would of thought but I will have a look later on cheers mate Quote
Kingofcars Posted May 15, 2015 Posted May 15, 2015 Yeah should be but awkward if not pal ;) Haha send me a PM when you want one mate Quote
