Glanza-Ben Posted May 14, 2015 Posted May 14, 2015 My evo fucked its engine big time, valves, pistons and spark plugs every where now the turbo looks fine no damage to the fins and spins freely would it show any damage if any parts of the internals went threw it Quote
mikey4410 Posted May 14, 2015 Posted May 14, 2015 remove the comp housing and exhaust housing and inspect real careful.also as for the internals I would blast out the crha and do that onto a white mint clean surface (such as a table covered in a4 paper) and carb clean it out heavily making sure it all goes straight onto the white surface......and metal pieces or similar will show up easy. Quote
Glanza-Ben Posted May 14, 2015 Author Posted May 14, 2015 remove the comp housing and exhaust housing and inspect real careful.also as for the internals I would blast out the crha and do that onto a white mint clean surface (such as a table covered in a4 paper) and carb clean it out heavily making sure it all goes straight onto the white surface......and metal pieces or similar will show up easy.Was gonna strip it to inspect just the fact im missing 3 valves but turbo looks mint i would imagine any size chunks would of ate my turbo fins and be obvious Quote
Glanza-Ben Posted May 14, 2015 Author Posted May 14, 2015 well if you strip u will need a rebalance that is true, fingers crossed its ok if not will be getting a bigger turbo ordered Quote
