destination unknown Posted February 11, 2008 Posted February 11, 2008 Has anyone any experience of putting a gt turbo engine into a 1 litre starlet? if anyone has any info it would be much appreciated. Quote
StarletRick Posted February 11, 2008 Posted February 11, 2008 it all depends on the mounts. im presuming they will be in the same place in the bay with different shaped block mounts. but ive never dealt with one so i wouldnt know. if that is the case. its the same as any other NA 4efte swap. not a difficult job, just time consuming. Quote
destination unknown Posted February 11, 2008 Author Posted February 11, 2008 it all depends on the mounts. im presuming they will be in the same place in the bay with different shaped block mounts. but ive never dealt with one so i wouldnt know. if that is the case. its the same as any other NA 4efte swap. not a difficult job, just time consuming.thats what i thinking but I've never done this before so its goin be a steep learning curve.i was hoping i could find someone who has so they could share some light into the problems im goin encounter. Quote
Domi Posted February 11, 2008 Posted February 11, 2008 The 4EFTE will fit straight into your car. All the engine mount are the same (the mount's that are on the car). The 1litre is an 2E right? If so the biggest problem is the wiring loom. Quote
destination unknown Posted February 11, 2008 Author Posted February 11, 2008 The 4EFTE will fit straight into your car. All the engine mount are the same (the mount's that are on the car). The 1litre is an 2E right? If so the biggest problem is the wiring loom.im not sure i tinks its a 1E. what difference does it make? Quote
