Bug679 Posted May 15, 2015 Posted May 15, 2015 Alright folks installed my jam fcd today and everytime i slow down it cuts out on me and even just on idle after start up it'll cut out to any ideas whats going on ? i followed the guide on toyotagtturbo to wire it in http://www.toyotagtturbo.com/forums/showwiki.php?title=How+to+install+a+JAM+FCD+via+the+MAP+sensorany help always appreciated guys Quote
Nick666Akers Posted May 25, 2015 Posted May 25, 2015 Hi mate, have you soldered the FCD in? If not do so as I was having similar symptoms after the previous owner didn't solder & used chocolate blocks. Quote
Bug679 Posted May 25, 2015 Author Posted May 25, 2015 Thanks man I'll give that ago as I only have it clipped if I ever wanted to take it off. Quote
Bug679 Posted June 12, 2015 Author Posted June 12, 2015 it's still cutting out after soldering it in think it could be faulty is there any way to check these out with meter or anything ? Quote
Duduglanza Posted June 13, 2015 Posted June 13, 2015 Try unplug it and see what the car does.. and if it runs ok check that you didnt switch wires.. make sure connections are good! Quote
Bug679 Posted June 18, 2015 Author Posted June 18, 2015 Cheers for the help lads 👍🏻 turns out was a bad earth rewired it and got a good earth and ally good now. Just keeps blowing the silicone hotpipe off now when I turn up the boost lol. I'll get that sorted doh 😀. Thanks again Quote
