found the wiki on rebuilding the td04 but havent found one for the ct9
just need to know spanner size of turbine nut, tried 9mm and 10mm but need to know the half measurment (ie 12.5mm = 1/2")before i can buy one.
cheers
The main tool you need is a balancing machine. Without this it simply cannot last, you wouldn't drive with unbalanced wheels so why drive with such a vital component like the turbo out of balance. we can balance it should you require. But our labor charge on the rest is small anyway.
i used a 10mm metric socket amigo
mark the exhaust prop at 12 or so and on the housing do the same on the compressor side blade and housing and over the nut centre shaft
so when putting back together you know the position of the blades
or find a billet ballenced comp wheel :) :)
