yuh these were my results on the fhe
Piston 1 - 160psi (max = just under 200psi)
Piston 2 - 145psi (max = 170psi)
Piston 3 - 150psi (max = just under 170psi)
Piston 4 - 90psi (max = 105psi)
so basically 2 engines need rebuilding
no get some rings in your local motor factors 4efe/5efe rings best to do it now then , there cheap to get , if they say no tel them for the corolla 4efe they will do just fine make sure to gap the rings
Edited by 5e colin
i have used them extra before the 1s in this engine i have used 2x
if you do make sure the threads of the bolt are clean and also clean out the threads in the block make sure there empty
you dont want them half full of oil giving false readings when torquing ( airgun and brake cleaner :) :)
