BoostAddictt Posted May 30, 2015 Posted May 30, 2015 Item For Sale: cusco lsd Item Condition & Description: here I have my cusco lsd the diff its self and actually gearbox work a treat, really is a brilliant peace of kit. How ever there is slight damage to the gearbox where the bolts go. It needs either new brackets mounting or possibly a weld either way it's a very easy fix. Especially if you no somebody handy with a weld gun. like I said this does not affect the performance of the gearbox in any way shape or form it simply just needs new brackets. The dif it's self was fitted by tuning developments (I have proof) reciepts etc would be perfect for somebody wanting a cheap lsd really was the best mod I did to my forged glanza absolutely transformed the car can't rate it enough. Price: £400Pictures: The damage as you can see it's a easy fix. Looks worse than what it is Really is a bargain at this price these things cost £££ newPayment & Shipping Details: will arrange with buyer Quote
AdamB Posted May 30, 2015 Posted May 30, 2015 Have you got mounts & shafts? It's aftermarket not OEM, so just use stock mounts and shafts for a non-lsd box. Quote
BoostAddictt Posted May 30, 2015 Author Posted May 30, 2015 (edited) As Adam said ^^you can run this LSD with stock shafts unlike Oem diffs much better than Oem tho ;) Edited May 30, 2015 by BoostAddictt Quote
BoostAddictt Posted June 1, 2015 Author Posted June 1, 2015 (edited) ... Edited June 1, 2015 by BoostAddictt Quote
Phil Posted June 1, 2015 Posted June 1, 2015 (edited) Are the shafts stuck in the box?And the box is alloy hardly an easy fix?You would need to fix it though cause if you can't get the shafts then you can't get the diff out and transfer it to another boxAsking cause half interested in making you an offer but just trying to understand if I'm buying a big ornament lolPhil Edited June 1, 2015 by Phil Quote
aaddzz123 Posted June 1, 2015 Posted June 1, 2015 Alloy welding the snapped metal back on isn't that much of an issue if you still have it. Mig welding alloy is surprisingly easy with the correct set up. Although if the remains aren't there anymore you may have to improvise to make it work again... Would be better off transferring everything into a new case, which is a bit of a dirty smelly mess of a job. Quote
ttestarlet Posted June 2, 2015 Posted June 2, 2015 Best diff ever! Best performance mod in my opinion. As for the welding goes, personally I'd be replacing the casing. I am a welder by trade.Yes welding will work but the cusco diff is hardcore and at low speeds feels like it's trying to bang it's way out of the box. Maybe less so with different oil but even if you do find a way to make it sound less harsh, you will still drive it hard giving it a hard life. You wouldn't be buying this otherwise.Also I'm sure east coast customs made braces for that mount because they were breaking.Good luck with the sale! Awsome piece of kit. Quote
BoostAddictt Posted June 2, 2015 Author Posted June 2, 2015 Sorry guys only just seen your coments.. Id do this for £350 the diff its self is in perfect working condition.. As stated above the cusco lsd is a brilliant peace of kit this is a bargain at £350 a new mint conditiom low milege gearbox can be sourced for peanuts £350 Quote
BoostAddictt Posted June 2, 2015 Author Posted June 2, 2015 Prov sold awaiting payment.. Also the shaft as been removed just for people's minds to be at rest Quote
Phil Posted June 2, 2015 Posted June 2, 2015 Prov sold awaiting payment.. Also the shaft as been removed just for people's minds to be at rest Sounds 100% then Phil Quote
