Arnold Posted June 5, 2015 Posted June 5, 2015 Hi all I've finally got the correct sized LED's i need to swap out on my front indicators, however as they didn't work, i'm told they are reversed polarity and I need to swap the wires over. Easy enough to do if i cut and swap the wires around, but does anyone know if it's possible to remove the wires from the bulb holder and swap them over that way? CheersArnold Quote
jellybaby Posted June 5, 2015 Posted June 5, 2015 Should b able to swap the wires round in the plug feller if u can get the terminals out of the connector use a very small flat blade lift the clip holding the terminal in place and pull should come out Quote
Arnold Posted June 9, 2015 Author Posted June 9, 2015 I couldn't get the terminals out mate, so I might have to cut and re-join. I'm sure it's possible, I just couldn't figure it out! Quote
jellybaby Posted July 25, 2015 Posted July 25, 2015 did u get it sorted feller also have u got led rear bulbs ??? if so what size did u get as I have a 96 glanza but now have reflect units which means I need to have a red bulb for the clear area on the lights Quote
