PaddyDoyle Posted June 10, 2015 Share Posted June 10, 2015 Will the LSD out of an AE111 BZR (C160) fit in the diff casing of a starlet C series box (Non LSD)?Can you make a non LSD box into a LSD? And what cups/drives would need to be used? Quote Link to post Share on other sites
morgey Posted June 10, 2015 Share Posted June 10, 2015 Yes it will fit. You will need to swap the ring gear from your current diff. Everything from your starlet will fit fine. Quote Link to post Share on other sites
PaddyDoyle Posted June 10, 2015 Author Share Posted June 10, 2015 It has to be a box from a non-turbo though right? Turbo boxes ring gears are 8 bolt and ae111 BZR ring gears are 6 like N/A starlet boxes?And what cup/drives are used? Quote Link to post Share on other sites
morgey Posted June 11, 2015 Share Posted June 11, 2015 No bzr boxes use 8 bolt diffs so drop into turbo boxes, not na ones. Use your starlet cups and driveshafts Quote Link to post Share on other sites
