Help! Wrong clutch or bottom end ?
Right guys any help is much appreciated , so I've got a glanza but it seems like the car has a turbo top end and a n/a bottom end , because the clutch is 200mm in diameter ? When it should be 212mm thanks!
Well the sump has a feed to it is like a bolt then the silicone hose? So I'm guessing it could be a flywheel and clutch? Trouble is I've now got three glanza clutches that don't fit haha
  On 6/13/2015 at 3:37 PM, 5e colin said:
look to the left ( 3 inches ) of the oil pressure sensor is there a drain bolt ??? only turbos have them !!
Where abouts is that bud?
its highly likely your bottom end is a na bottom end
