KPJUK Posted June 16, 2015 Posted June 16, 2015 Hi everyone, I'm not really in the know with these but I need an ECU to run my 1999 4E-FE from a Corolla. It's the 3rd generation engine and won't run for more than a second thanks to the ECU cutting the engine due to an immobiliser issue. Does anyone have a JDM ECU that will work with this engine that doesn't have an immobiliser. Preferably plug and play but can repin if necessary. KP
daniel_g Posted June 16, 2015 Posted June 16, 2015 You'll need an ECU that uses the DIS Ignition system from the Gen3 FE, theres a dude on here selling an EP95 ECU in the forsale section.I think it might work but i duno if the later starlets like the one its out of had an immobiliser, it was from a 99 starlet.
KPJUK Posted June 16, 2015 Author Posted June 16, 2015 Thanks for the reply I managed to get it going - key was too close to the antenna and now she starts. Unfortunately there is a huge sump leak and the belt covers need replacing. KP
