J40k-mo Posted June 30, 2015 Posted June 30, 2015 Glanza wants to stall all time like tick over is too low! For an example I was slowing down to a roundabout from 3rd and dipped clutch, once revs dropped to tickover they went top low, looks like on dials to be below 500 and cut out, then once u bump it or turn over on key it fires back up, but wants to tick over very low! This is only once warm it's mint when cold and chokes on,Can u turn tick over up? Or anything to do with Tps? Cheers guys! Quote
Duduglanza Posted July 1, 2015 Posted July 1, 2015 Give a good clean to the idle control valve . It takes care of the idle while the engine is cold. Quote
J40k-mo Posted July 1, 2015 Author Posted July 1, 2015 Is that the one on the left hand side of inlet?And does it help it when it's warm?Cheers Quote
