J40k-mo Posted June 30, 2015 Share Posted June 30, 2015 Glanza wants to stall all time like tick over is too low! For an example I was slowing down to a roundabout from 3rd and dipped clutch, once revs dropped to tickover they went top low, looks like on dials to be below 500 and cut out, then once u bump it or turn over on key it fires back up, but wants to tick over very low! This is only once warm it's mint when cold and chokes on,Can u turn tick over up? Or anything to do with Tps? Cheers guys! Quote Link to post Share on other sites
Duduglanza Posted July 1, 2015 Share Posted July 1, 2015 Give a good clean to the idle control valve . It takes care of the idle while the engine is cold. Quote Link to post Share on other sites
J40k-mo Posted July 1, 2015 Author Share Posted July 1, 2015 Is that the one on the left hand side of inlet?And does it help it when it's warm?Cheers Quote Link to post Share on other sites
