nikhilkamdar12 Posted July 7, 2015 Posted July 7, 2015 (edited) Hi guys, I have the EP3 COP and need the pinout for the coils. I'v looked everywhere online and cannot seem to find a solid answer to which of the 3 wires are for. I know one will be 12v, ground and the other signal but which one is which? Any help will be much appreciated Managed to find this online... If anyone can tell me if this is correct pinout for the EP3 civic coils? Nik Edited July 7, 2015 by nikhilkamdar12 Quote
Stu Posted July 9, 2015 Posted July 9, 2015 (edited) Looking at the plug it should be (left to right) Trigger > Earth > 12v so the illustration above looks to be correct. Should suit K20/K24/F20C What are the wire colours? Edited July 9, 2015 by Stu Quote
nikhilkamdar12 Posted July 9, 2015 Author Posted July 9, 2015 (edited) Looking at the plug it should be (left to right) Trigger > Earth > 12v so the illustration above looks to be correct. Should suit K20/K24/F20C What are the wire colours?Cheers for the respond dude I have no wires coming out of them unfortunately as I bought the coils and clips separate and the clips came brand new with no wires in them. I'm wiring the Haltech into them so I have all the wires ready to go. Just to clarify looking from the back of the connector as you mention is the correct pinout. Trigger, Ground and 12v.Thanks Nik Edited July 9, 2015 by nikhilkamdar12 Quote
Stu Posted July 12, 2015 Posted July 12, 2015 (edited) Yeah so looking directly at either the wire side of the plug or into the plug socket in the coil itself. Did you want that dwell table? Edited July 12, 2015 by Stu Quote
nikhilkamdar12 Posted July 13, 2015 Author Posted July 13, 2015 Perfect, Yeah sorry I didn't get back to you about that! I haven't set up the base map yet I was just gathering all the info about the parts I have to enter into the Haltech. Shall I contact you closer to the time when I have it all hooked up? Quote
nikhilkamdar12 Posted July 18, 2015 Author Posted July 18, 2015 Hi, Coming to actually wire up my coils now and i'v for some reason just forgot the wiring of where the trigger wire goes to, from the COP? So I will feed it 12v continuous and wire a switched ground to it. Now the trigger do I leave it or do I wire it up? As the ECU tells it when to fire as its getting the signal from the cam VR sensor and works it out this way? Nik Quote
Stu Posted July 19, 2015 Posted July 19, 2015 The trigger is from the ignition output channels from your ecu - I'm assuming you have at least two or it wont work Quote
Stu Posted July 20, 2015 Posted July 20, 2015 Sorry, just read this again - this isn't right, the 12v feed is switched from the main efi relay (use the original coil power feed and split to the 4 COP's, the earth is a constant and should be earthed to the cylinder head/inlet earth point. It may pay to check your ecu documentation as this really should all be in there. So I will feed it 12v continuous and wire a switched ground to it. Quote
nikhilkamdar12 Posted July 21, 2015 Author Posted July 21, 2015 Sorry, just read this again - this isn't right, the 12v feed is switched from the main efi relay (use the original coil power feed and split to the 4 COP's, the earth is a constant and should be earthed to the cylinder head/inlet earth point. It may pay to check your ecu documentation as this really should all be in there. Cheers for the info mate, all sorted now I think I was getting confused to whether the output was a switched ground or a trigger! So trigger from ECU goes to trigger pin, ground goes to the head and 12v power is switched from the ECU EFI relay from the haltech wiring loom all done for me I'll get wiring and let you know how it goes. Also I have heard only K20 coils something is inverted and if you don't invert it on the ECU via the software you can or will blow a coil? Nik Quote
Stu Posted July 22, 2015 Posted July 22, 2015 (edited) Yes the spark edge for them is Rising Edge not Falling Edge which is more conventional for Toyotas Edited July 22, 2015 by Stu Quote
nikhilkamdar12 Posted July 22, 2015 Author Posted July 22, 2015 Yes the spark edge for them is Rising Edge not Falling Edge which is more conventional for Toyotas Sweet, good info here Once i'm done with the base map i'll get it sent across to you to double check it's all good to go Quote
