BillyM247 Posted July 13, 2015 Posted July 13, 2015 Might sound a silly question but how would I tell if I have an LSD gearbox? Cheers Quote
Jamie_VF22 Posted July 13, 2015 Posted July 13, 2015 jack it up spin the wheels if they turn the same way you have an LSD , Quote
BillyM247 Posted July 13, 2015 Author Posted July 13, 2015 So jack it up put it in gear with both wheels off the floor and they should both spin? Or out of gear? Don't really know much about LSD's :/ Quote
akyakapotter Posted July 13, 2015 Posted July 13, 2015 (edited) You will no If you have one they drag you into corners out of gear pal Edited July 13, 2015 by akyakapotter Quote
morgey Posted July 13, 2015 Posted July 13, 2015 Not all lsd's work like the above mentioned. The oem levin lsd's require a torque input to lock which wont happen with both wheels in the air. Clutch types generally will though. Then youve got the more obvious oem starlet lsd which is a big cone off the side of the box behind the engine. Quote
