kevmcc90 Posted July 15, 2015 Share Posted July 15, 2015 Went to change bulbs in car today. When I went to unlock it using the button (toad alarm) the central locking wouldn't open. Manually opened door. Then the dash would like up when keys turned in ignition but wouldn't start. Battery is fully charged and I had the car out for a run the other day and all was fine. I've ran out of ideas? Quote Link to post Share on other sites
kevmcc90 Posted July 15, 2015 Author Share Posted July 15, 2015 The work I've done recently on car is change the dash and cluster bulbs to led, and fitted race spec rocker cover and catch can. As I said it ran fine and now won't start. I noticed the battery light and that light up fine but when your turn headlights on some of the lights go out and headlights don't light? Quote Link to post Share on other sites
Starlet__SR Posted July 15, 2015 Share Posted July 15, 2015 Have you tested the battery to make sure there's enough voltage there?Day Quote Link to post Share on other sites
kevmcc90 Posted July 15, 2015 Author Share Posted July 15, 2015 On 7/15/2015 at 10:35 AM, Starlet__SR said: Have you tested the battery to make sure there's enough voltage there?DayYeah mate first thing I did, 12volts on battery. I'm not sure if it's something to do with the alarm system? Quote Link to post Share on other sites
WallaceGlanza Posted July 15, 2015 Share Posted July 15, 2015 Sounds like an immobiliser issue, probably a fuse somewhere for it, check the alarm wiring. Quote Link to post Share on other sites
StuDoc 72 Posted July 15, 2015 Share Posted July 15, 2015 Have you changed the battery in your key fob? Quote Link to post Share on other sites
kevmcc90 Posted July 15, 2015 Author Share Posted July 15, 2015 On 7/15/2015 at 12:02 PM, StuDoc 72 said: Have you changed the battery in your key fob?Yeah changed the battery and had same issue. Will have to have a look into the alarm wiring like you say Wallace. Quote Link to post Share on other sites
cellohan94 Posted July 15, 2015 Share Posted July 15, 2015 EFI FUSE? Quote Link to post Share on other sites
StuDoc 72 Posted July 15, 2015 Share Posted July 15, 2015 If its not the battery on the key fob im 99.9% sure its the car battery. Hook some jump leads up to a running car and see if it makes a difference. Your headlights should work regardless when the ignition is on and if when you are turning them on and the dash lights are fading its pretty much a stick on to be the battery. Quote Link to post Share on other sites
kevmcc90 Posted July 15, 2015 Author Share Posted July 15, 2015 I've got the battery on charge the now but it's saying it's fully charged Quote Link to post Share on other sites
StuDoc 72 Posted July 15, 2015 Share Posted July 15, 2015 I know mate but going by the sounds of it and the fact that the dash is fading when you turn on the headlights. Do you have jumpleads at all? I know it says its fully charged but I've had to replace many a battery that says its 12v but is knackered. Batteries can say they are 12v but they need to be drop tested aswell as they may not be able to maintain a load put on them. Best thing you can do is stick the battery in your car get another car and keep the engine running, stick some jump leads on between the 2 cars and if your central locking and everything else still doesn't work then its not the battery. Quote Link to post Share on other sites
kevmcc90 Posted July 15, 2015 Author Share Posted July 15, 2015 On 7/15/2015 at 1:21 PM, StuDoc 72 said: I know mate but going by the sounds of it and the fact that the dash is fading when you turn on the headlights. Do you have jumpleads at all? I know it says its fully charged but I've had to replace many a battery that says its 12v but is knackered. Batteries can say they are 12v but they need to be drop tested aswell as they may not be able to maintain a load put on them. Best thing you can do is stick the battery in your car get another car and keep the engine running, stick some jump leads on between the 2 cars and if your central locking and everything else still doesn't work then its not the battery.OK mate will give it a bash Quote Link to post Share on other sites
Zoib_786 Posted July 28, 2015 Share Posted July 28, 2015 (edited) Same issue !!!! But my immobiler works. Car was working perfect now when you go to start it. It just makes a click and the dash lights up with battery check engine and starts fading away like the battery's fucked. Help needed Edited July 28, 2015 by Zoib_786 Quote Link to post Share on other sites
kevmcc90 Posted July 28, 2015 Author Share Posted July 28, 2015 On 7/28/2015 at 2:58 AM, Zoib_786 said: Same issue !!!! But my immobiler works. Car was working perfect now when you go to start it. It just makes a click and the dash lights up with battery check engine and starts fading away like the battery's fucked. Help needed I just bought a new battery and that sorted the problem. Although I was getting full voltage on old battery it wasn't strong enough to start car. Best bet is fit a new battery Quote Link to post Share on other sites
Zoib_786 Posted July 28, 2015 Share Posted July 28, 2015 Cheers mate will try a new battery Quote Link to post Share on other sites
