I bought an alarm/immobiliser kit. The immobiliser is a relay that can kill a single wire, I'm wondering where the best place to put it is. Current thinking is fuel pump, is this a good call? If so, what's the best way to access the wiring for it from under the dash?
best not to mention where you going to put it on the net
but if you are clever you can cut of any system of your liking in the car make sure no1 can find it i would not do fuelpump because every1 does pump so easy to run wire to it
pm me i have a good tip for you
