Ep91 slam panel
No, the panel the bonnet catch and horn is attached too. I know it's spot welded in but was hoping if someone had a shell they could drill spot welds out and remove it. I can have one from Toyota for October (on back order from Japan) but don't want my car off the road for that long.
Cheers pal. Appreciate you keeping me in mind. Could always humour me with a number to see if it's worth your while? I'll take the headlight brackets too if you want to split the slam panel from the shell if it makes a difference?
