Engine rebuild, stiff when trying to turn over (new rings and bearings)
As in the title just fitted new rings and big end bearings.
Used plastigauge and got the following:
Piston 1 - 0.048
P2 - 0.048
P3 - 0.035
P4 - 0.038
Torqued bolts up 20 and then 40nm
is ok turning on pistons 2+3, gets stiffer on 4 and then jammed on 1.
What's the next step here?
Cheers
Fyi acl standard 4efte bearings
means a bearing is to tight amigo
have u measuring toools to measure the bearings and hole itselve ??
check the nr1 again with plasigauge because u should be able to turn the engine by hand if the pully is on it :) if you cant its to tight and will destroy the bearing and burn the lobe
Edited by 5e colin
