I'm looking to swap my ep80 headlights to ep82 quadlights could anyone shed some light on what connects up to what? I know they are projector lamps on the quads & there's more bulbs in the quads just wanted to know what bulbs serve what purpose & best way to wire it all up, really hard to explain sorry guys
no1 will swap quads for squares but they are a strait fit if you have al the hardware you need to shop your current bulb connector of and hard wire it in you will loose the 4 lights burning its either driving lights or fulls not al 4 as on a quadlight car
If you use all the brackets from the quads then they will bolt in. You need to set a rivnut into the top cross member if you wanted to use the top stay. Wiring wise there is a guide floating around with a diagram. You do need to trim out the headlight surround to make them fit.
