Flynn Posted July 30, 2015 Share Posted July 30, 2015 Can I adjust the door at all? Or do I need to replace worn parts? Can literally lift it by an inch and it's smacking off the skirt before closing 😒 Quote Link to post Share on other sites
JDMfreak Posted July 30, 2015 Share Posted July 30, 2015 I actually fixed one of these the other day pull the wing off much handier to work at I took the hinge off that was causing the agro and filled it a bit making it adjust ie move hinge back door drops move it forward door lifts so I could make it lift more even though it could lift a bit more with the hinge been worn as I didn't have any other option didn't have a hinge to replace it with ive seen a few people take the hinge off cut the door pin take it out weld a washer over the original pin hole and replace the pin no more worn door hinge for a good while Quote Link to post Share on other sites
Flynn Posted July 30, 2015 Author Share Posted July 30, 2015 I've got a spare door but it's black can a rob any bits off that? Quote Link to post Share on other sites
JDMfreak Posted July 30, 2015 Share Posted July 30, 2015 if its got a hinge ya might be able to swap it over Quote Link to post Share on other sites
Flynn Posted July 31, 2015 Author Share Posted July 31, 2015 Yea they've got hinges, I'll have to have a play! You had any joy with getting that glow barrel in? Quote Link to post Share on other sites
JDMfreak Posted July 31, 2015 Share Posted July 31, 2015 Yeah 5 min job swapping hinges makes a great difference door close so easy...yeah got the glow barrel and footwell light fitted tapped into door switch and a ignition power Quote Link to post Share on other sites
