JDMfreak Posted July 31, 2015 Posted July 31, 2015 right a friend asked to post this up his glanza v has an abs fault and its always on we did the abs diagnostics and came up with code 32Left front wheel sensor signal malfunction. We replaced the sensor and reset it but light still solid on now one thing I did notice the abs pump doesn't make the hum sound mine does when light goes off am I right in thinking his abs pump is wanked we have another one here to try on it can I just plug it in a check it with out all the pipes connected Quote
5e colin Posted July 31, 2015 Posted July 31, 2015 did you test the wire from sensor to abs ecu ?? might be faulty Quote
JDMfreak Posted July 31, 2015 Author Posted July 31, 2015 We were going to swap the abs ecu for mine as my abs ecu is working we have a abs pump but I don't think pump is gone Quote
