*Misfire on boost please help!*
So, about a week ago, my car developed a misfire only on boost just after 6k revs, was only in 3rd at that point but now it's in every gear. It's not fuel cut as I have a JAM ecu. It feels exactly like fuel cut, but it's not.
I have cleaned the coil/igniter connectors and made sure it has a nice contact with the Bulk head.
Tried different leads, cleaned rotor arm & dizzy cap even though they and the leads was new a few months ago.
Not tried new plugs get, not done anything with the plugs.
What could this be? My cars spec is bellow if needed
Speed vision gen2 hybrid ct9 @1.2 bar
Jam ecu
Magnacore 8.5 leads
Side exit exhaust
FMIC
Iridium plugs heat range 6 *i think*
Walbro fuel pump
Athena 1.2 metal head gasket
Please note it did this even at .8 bar with standard ecu.
Going to re-check timing tomorrow and replace the plugs hopefully.
Thanks people :)
Swap the plugs out for normal ones and go to a 7 heat range for that boost. Something like BKR7ES. Then gap to 0.75-0.8mm for starters. They're cheap plugs and much more forgiving to over fueling that iridiums.
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
