they do say you have to check there still in spec.
when torque-ing them down, they need to stretch to a curtain length. before you reuse them you need to measure the overal length of the bolt if its still in spec.
if so reuse, if not in the bin and new ones.
i have PEC rods and im not sure if the specs are the same. get hold of the information witch comes with them and start measuring !
Yes very important you check the bolt length. For the cost of new one's it's a no brainer as this is the most stressed fastner in the engine.
