Can I just bolt a ct9 hybrid on now if it's worth my time? Only after turbo don't want to be changin lots? as my standard ct9 has cracked or should I replace it with another standard one? Just want bolt on ideally
If your using the standard manifold and decat then you would want to be port the restriction off of the manifold and knock the honeycomb out the cat or get a de-cat.
Your results will improve 10 fold if you do these.
So putting a hybrid turbo on I wouldn't have to change anything else? It would operate fine on a totally standard engine? Will decat ect eventually!
Will operate perfectly fine.
If you have a standard mani then just get a dremmel tool and port the mani while you have it off. It doesnt cost anything and would be silly not to do.
Does anyone on here have a hybrid for resonance price? Or I'll just get another standard and that will be a mod for the future when I get an upgraded acuator too, Ok mate it wouldn't mess with any emission sensors or anything doing that?:) will be decat soon too!
