BillyM247 Posted August 14, 2015 Share Posted August 14, 2015 (edited) I have a starlet SR with a gt turbo engine in, get turbo ecu etc and I'm tying to cure a misfire which only happens at 6k revs. I've replaced most things part from map sensor and coil/igniter. Are the map sensors interchangeable from ep82 & ep91? Edited August 14, 2015 by BillyM247 Quote Link to post Share on other sites
Socks Posted August 14, 2015 Share Posted August 14, 2015 Yes they are Different mounting brackets tho! Quote Link to post Share on other sites
BillyM247 Posted August 14, 2015 Author Share Posted August 14, 2015 Thanks man ! Can you swap the brackets round or would I just need to mount it differently/modify the bracket? Quote Link to post Share on other sites
