have recently started my project and am not far from finishing but have come across some problems
firstly I bought a normal starlet that some had had previously converted with a 4efte engine with most or the td04 kit on it. it was rotten so I stripped the car and bought a cat d light panel work glanza s downer car that I would be putting the 4efte engine in to
every things in now engine shafts wheels linkages etc the only mistake I made thinking that I wouldn't need the dash loom so I scrapped the car with this still in lol
any way I definitely need this rite as I can see that the glanza s dose not have the key reader ring around the key hole what exactly do I need to change in the car for the conversion is there any other looms I need to change that I might have scrapped like the fuel pump loom etc .. ?
I need a wiring diagram if possible showing earth points etc
what size exhaust/bore size would I need for the td04 setup as I don't think its rite one that previous owner has used ?
and if any ones out there has a diagram to plumb in a fuel pressure regulator ?
one other thing I have come across when I stripped the other car it didn't have power steering I would like to put this on the car so I took it off the glanza s engine and put it on the 4efte engine before putting the engine back in glanza s shell I cant seem to get the brackets on off the glanza s engine as it hits the oil sandwich plate where oil filter is do you know if the brackets and adjuster for belt tension is the same off n/a engine to the turbo engine or any pics that could point me out
getting quite stressed as its near enough finished any help would be much appreciated you guys cheers
  • 2 months later...
