Is this the proper way to convert our distributor to coil pack ignition system using honda d17 coils from 2003-04 civic??
i doubt it as its so easy to do!!!
Sadly no that doesnt work with a 4e/5e ecu.
You can run COP if your engine/ecu has multicoils as you can convert the COP to run wasted spark too, but single coil wont work.
