I was charging the battery on my 98 glanza V, it was raining so I closed the door for a sec and it decided to lock its self with my keys inside. it has a toad alarm.
I am desperate so please any help don't hesitate to contact me.
Long wire coat hanger in through the drivers door hook it round the passenger door handle and pull it open had to do it loads of times because of my stupid alarm
through the door seal? and unfortunately I can't open the doors from the inside when its locked, would disconnecting one battery terminal and reconnecting it quick jog the alarm?
yeah I used to just put it through the door seal and pull on the handle twice with the hanger and it popped open.. Only other way without causing damage to the car would be try and hook the wire coat hanger round the boot opening catch and go in through the boot
ive got a wiper delete, any way that could help to get in?
No mate just hook it round the boot opening catch and pull up it's so easy dude
from under the boot? or through the window. plus where is the catch? can't say i'd make a great car robber
Lol have you never opened your boot ? Go in through either the drivers or passenger door with a wire coat hanger with a hook on the end and the boot opening catch is by the right of the drivers feet you know beside the fuel cap opening catch lol
you can even open them by making a deep hook slide it down between glass and window trim turn it so the hook goes up under the glass try to push up the door pin
