Sportif 4efte Posted August 26, 2015 Share Posted August 26, 2015 Hey guys go a conversion underway and have an issue with connectors connecting from engine to dash.The only engine is off a 1998 Glanza v import.Would I have to get a separate dashloom for my 1.3 4efe UK to jdm import version or are there any ways around it? Quote Link to post Share on other sites
RobSR Posted August 26, 2015 Share Posted August 26, 2015 Buy a gt engine loom and splice it in is the easiest way. You just add the couple of bits you need to your na loom.Failing that you need to swap the entire car to Glanza stuff. Quote Link to post Share on other sites
Sportif 4efte Posted August 26, 2015 Author Share Posted August 26, 2015 Jdm Loom (left)UK spec Loom (right) Quote Link to post Share on other sites
Sportif 4efte Posted August 26, 2015 Author Share Posted August 26, 2015 On 8/26/2015 at 8:49 PM, RobSR said: Buy a gt engine loom and splice it in is the easiest way. You just add the couple of bits you need to your na loom.Failing that you need to swap the entire car to Glanza stuff. Quote Link to post Share on other sites
Sportif 4efte Posted August 26, 2015 Author Share Posted August 26, 2015 Got most of the Glanza bits mate just hoping to find another way round it, not to keen on splicing at the min but is a last option...cheers Quote Link to post Share on other sites
RobSR Posted August 27, 2015 Share Posted August 27, 2015 Well they are the two options really. Fit all the Glanza stuff or splice the bits from the gt loom you need.Seeing as you'll need to pull the whole car apart to swap the looms splicing it will be the quicker and easier option. The looms are basically the same, just need to move a few pins on the ecu and add a couple more wires for the different ignition setup, knock sensor etc Quote Link to post Share on other sites
