kyle_h95 Posted August 27, 2015 Share Posted August 27, 2015 Okay, I think I know the problem here, I just want to assure myself I'm not going to waste my time lol.Okay so, as title says, my gears don't fully disengage when I dip the clutch.So basically I was trying to show off and make some noise in front of some friends... dipped the clutch while in 2nd gear, and as it got high rpm car started pulling away!Not bad, but definatly noticeable, and I found it doesn't always happen!I have a noise from clutch release bearing ( from a 2 month old bearing) :/ Would this be the fault here? Thanks in advance! Quote Link to post Share on other sites
Sefton-EP91 Posted August 27, 2015 Share Posted August 27, 2015 What clutch is it mate? A few people having problems at the moment with clutch dragging. Quote Link to post Share on other sites
Vturbo Posted August 27, 2015 Share Posted August 27, 2015 Had the same problem, it was the release bearing, swapped it out for an genuine bearing and it was all good Quote Link to post Share on other sites
