I've just bought a emanage off someone who got it with his car but didn't know what the harness was for this didn't bother me to much as was just going to get it hard wired in but the harness plugs straight into my starlet does this mean is for a starlet or its just a coincidence?
There are 3 plugs and 2 fit (my ecu only has 2 plugs anyway) but looking on eBay all starlet harness are like that
okay so I've checked it against a ep91 wiring diagram and it isn't after searching online i cant fond what its for so i want to adapt it for the ep82, where can i get a wiring diagram? for ep82?
Just use the many ecu pin out diagrams that are on Google. Harnesses are simple pin one goes to pin one and pin two goes to pin two..... you just need to know which wire does what so you can connect up what you need.
Yeah looking closely that's not a ep91 loom the two outside plugs look the same size where ep91 has three different size plugs.
