Am at the end of my tether here and after some advice / help.
I have what I thought was all the parts to convert gearbox to an OEM LSD version. Tried to bolt the bracket onto the box to find it is different also.
Anyone have one lying around or know of an easy fix?
Have the box, shaft, gearbox mount and sandwich plate but now need the rear bracket.
Any help or advice appreciated.
Many thanks
Mark
Your best off adjusting/making one with the one you've already got.
Toyota wanted £125 for when when I tried to get on a couple of months ago. I ended up shortening and welding the one I already had to make it fit. Not to bad a job to do if you know someone who's good with a welder.
I may have the pay the price then 😞, I can't weld, needs someone to fabricate something for me which will cost a lot too,
The search continues 👍.
I'm not giving up haha !!
Thanks thougg
Can anyone help me here ?
I am after the part number for the rear gearbox bracket for a factory OEM LSD box
Or a car that was fitted from the factory with this box - reg no.
My local Toyota parts department cannot help me unless I have these details.
Any help is appreciated
Many thanks
Mark
